Blocked IP addresses in Russia
In the fight to ban the messenger Telegram, the Russian government blocked a large number of IP addresses. In this lock were the domain names discovery-XXXXX.syncthing.net. Is there a way to make the program workable in this situation?
It feels like you have syncthing misconfigured, as I think those discovery servers have been deprecated.
Just remove the custom discovery addresses and set the field value to “default”.
  1. Until April 16, 2018, the synchronization worked. On the site, about blocking ip addresses, the information coincides that these addresses were blocked on April 16.
  2. In the program, I did not make any adjustments, these addresses are set by default. I would be happy if you tell me where and to what addresses I can replace?
I think new urls have recently been introduced, but the old ones purposely still work to keep it working for the pretty significant userbase on old versions.
I guess someone can set up discovery servers in Russia for russian users, or you can wait for the hysteria to pass and the blocking to be released maybe.
(From the no-such-host reply I’m guessing it’s maybe cloudflare’s dns that’s blocked?)
I have 2 hardware devices:
  1. QNAP NAS, the installed version of v0.14.46, Linux (ARM) (This is the latest version.)
  2. free4nas v0.14.30, FreeBSD (32 bit).
QNAP also has error messages:
Sorry that inserted a screenshot, not text, since the new user can not publish more than 1 link.
It is also unclear why the status of “Discovery” is 2/5. If there is no connection, then should be 0/5?
002
Local discovery over ipv6 and 4 counts as one each
Excuse me, I have connectivity problem too (Russia): One device (win pc) cannot see another devices (also win pc, another network). Everyithing was working yesterday, no changes was made.
How can I find a reason of this problem?
Good day, why the device has ceased to see each other (Russia), problems arise with the update, the server forcibly close the connection. What’s the matter? Who is aware of?
Connectivity is restored, thank you, friends!!!
I can’t confirm. Last time I saw my three devices working was 24/4. Luckily 2 of them have static IPs so I set direct address in settings to make them see each other again. Here are the discovery errors.
device #1:
global@https://discovery-v4.syncthing.net/v2/: Post https://discovery-v4.syncthing.net/v2/: dial tcp 51.15.215.88:443: connectex: No connection could be made because the target machine actively refused it.
global@https://discovery-v6.syncthing.net/v2/: Post https://discovery-v6.syncthing.net/v2/: dial tcp: lookup discovery-v6.syncthing.net: no such host
device #2:
global@https://discovery-v4.syncthing.net/v2/: Post https://discovery-v4.syncthing.net/v2/: read tcp XX.XX.XX.XX:XXXXX->51.15.215.88:443: read: connection reset by peer
global@https://discovery-v6.syncthing.net/v2/: Post https://discovery-v6.syncthing.net/v2/: dial tcp [2001:bc8:4700:2000::515]:443: connect: network is unreachable
device #3 (without static IP):
global@https://discovery-v4.syncthing.net/v2/: Post https://discovery-v4.syncthing.net/v2/: read tcp 192.168.63.1:2020->51.15.92.95:443: wsarecv: An existing connection was forcibly closed by the remote host.
Just so that everyone’s on the same page - the discovery connectivity or lack thereof in Russia is unfortunately completely outside of our control.
You’re all welcome to discuss & report of course, just be aware that any changes you see - positive or negative - are not due to actions by the Syncthing team.
I’m from Russia too, and I’ve encountered the problem described in https://forum.syncthing.net/t/syncthing-stopped-connecting-between-machines. May be these are related?
Have own discovery server (not located in Russia). Would the Russian’s in this thread like to try to use it?
Sure! :slight_smile:
My 2 cents: discovery problems are not persistent - sometimes nodes see each other, but not too long.
p.s. I like to try another discovery server. How can we do this?
https://discosrv.tk:8443/?id=554GCWZ-7TSUAIF-UEZPIWY-6AVBFKD-D77HEDC-6MT2QMO-KC542YI-EKUX2AC
Let know how it works for you. If many find useful will run as proper community contribution by moving to dot com with SSL certificate (making device ID not necessary) on port 443. Currently runs on port 8443 so will not work when only port 80 and 443 outgoing allowed.
Works perfectly, thank you!:+1:
