You want to pass -no-restart to syncthing
, not to su
not closed for me, I will check for running processes and report SIGABRT logs if it happens again (~ once per week)
topic revive got syncthing running once - and yes Iâm sure but gui isnât answering with ERR_TIMED_OUT (as described above) and logs full of
http: TLS handshake error from 109.XXX.XXX.33:55002: read tcp 109.XXX.XXX.33:55002: i/o timeout
It seems that you fail to get past the TLS handshake. Firewall, proxy issue?
If you run linux, just try to do curl -v <address>
and get the output.
the problem appears since the last 11.10. update on linux Debian GNU/Linux 7.8 (wheezy)(server@datacenter). so I dont believe that they chenged their securitysettings⌠any other idea without curl? (dont have it installed ) what does curl -v do?
Prints the handshake.
curl -v address of server right? but do I got it right: I need to run curl on the problem-server or on another pc?
On the UI you cannot access.
syncusr@cloud:~$ curl -v * Trying 85.XX.XX.204...
-bash: curl: command not found
syncusr@cloud:~$ * connected
-bash: SYNC: command not found
syncusr@cloud:~$ * Connected to cloud.mailify.de (85.XX.XX.204) port 8384 (#0)
-bash: syntax error near unexpected token `('
syncusr@cloud:~$ * successfully set certificate verify locations:
syncusr@cloud:~$ * CAfile: none
syncusr@cloud:~$ CApath: /etc/ssl/certs
-bash: CApath:: command not found
syncusr@cloud:~$ * SSLv3, TLS handshake, Client hello (1):
syncusr@cloud:~$ * SSLv3, TLS handshake, Server hello (2):
syncusr@cloud:~$ * SSLv3, TLS handshake, CERT (11):
syncusr@cloud:~$ * SSLv3, TLS alert, Server hello (2):
syncusr@cloud:~$ * SSL certificate problem: unable to get local issuer certifica te
syncusr@cloud:~$ * Closing connection #0
syncusr@cloud:~$ curl: (60) SSL certificate problem: unable to get local issuer certificate
-bash: syntax error near unexpected token `60'
syncusr@cloud:~$ More details here: http://curl.haxx.se/docs/sslcerts.html
-bash: More: command not found
fyi: I already restarted syncthing⌠(needed to restart server to install curl) should this be done when hanging?
Donât know what you did, but the log is a mess.
Try -v -k options, in a separate console window.
ok - to get sure: my server is running under https://cloud.mailify.de:8384 / 85.93.13.204 which one is the right call: curl -v https://cloud.mailify.de:8384 or just curl -v 85.93.13.204 ? sorry for such a mess of questions - Iâm semibeginner at debian
As I said, whichever address you access syncthing on. With -k -v options.
finally
root@cloud:~# curl -v https://cloud.mailify.de:8384
* About to connect() to cloud.mailify.de port 8384 (#0)
* Trying 85.93.13.204...
* connected
* Connected to cloud.mailify.de (85.93.13.204) port 8384 (#0)
* CAfile: none
* SSL certificate problem: unable to get local issuer certificate
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
curl -k gives: âNot Authorizedâ
Right, so it is accessible and it is listening. The problem must be with your browser/proxy/firewall which is outside of scope of syncthing.
You can add -k -u guiusername:guipassword which should get you the html output of the page.
remember:
at the moment syncthing stucks⌠these are my results:
result of pgrep:
260
output of netstat -tulpn | grep â8080|8384â
tcp6 0 0 :::8384 :::* LISTEN 260/syncthing
output of curl -v https://cloud.mailify.de:8384:
* connected
* CAfile: none
* SSL connection timeout
curl: (28) SSL connection timeout
curl -k -u:
-bash: !0: event not found
and I found
2015/06/29 19:00:39 http: TLS handshake error from 109.90.119.33:34075: read tcp 109.90.119.33:34075: i/o timeout
2015/06/29 19:01:55 http: TLS handshake error from 194.126.249.10:41537: remote error: unknown certificate authority
Session terminated, terminating shell... ...terminated.
this was exactly at 1:00 am this nightâŚ
It does seem that there is something in between you and syncthing thatâs causing the issue. Can you verify that the same thing happends when connecting via curl -v -k https://127.0.0.1:8384 from the same machine that runs syncthing.
root@cloud:~# curl -v -k https://127.0.0.1:8384
* About to connect() to 127.0.0.1 port 8384 (#0)
* Trying 127.0.0.1...
* connected
* Connected to 127.0.0.1 (127.0.0.1) port 8384 (#0)
* CAfile: none
while
root@cloud:~# pgrep syncthing
260
and
netstat -tulpn | grep '8080\|8384'
bit wired
Can you get the SIGABRT dump? Via kill -6 as explained earlier.
hmm:
[7QCUL] 06:35:06 INFO: syncthing v0.11.11 (go1.4.2 linux-amd64 default) unknown-user@syncthing-builder 2015-06-28 19:10:57 UTC
[7QCUL] 06:35:06 INFO: My ID: 7QCULIP-XXXXXXXXXXXXXXXXXXXXXXXXXXX-GJC57AF
[7QCUL] 06:35:06 INFO: Database block cache capacity 8192 KiB
[7QCUL] 06:35:10 OK: Ready to synchronize mp3s (read-write)
[7QCUL] 06:35:10 OK: Ready to synchronize s.a (read-write)
[7QCUL] 06:35:10 OK: Ready to synchronize wedding (read-write)
[7QCUL] 06:35:11 OK: Ready to synchronize MatadorSync (read-write)
[7QCUL] 06:35:11 OK: Ready to synchronize SarahCloud (read-write)
[7QCUL] 06:35:11 INFO: Starting web GUI on https://0.0.0.0:8384/
[7QCUL] 06:35:11 INFO: Completed initial scan (rw) of folder s.a
[7QCUL] 06:35:11 INFO: Completed initial scan (rw) of folder wedding
[7QCUL] 06:35:11 INFO: Completed initial scan (rw) of folder MatadorSync
[7QCUL] 06:35:11 INFO: Completed initial scan (rw) of folder SarahCloud
[7QCUL] 06:35:12 INFO: Starting local discovery announcements
[7QCUL] 06:35:12 INFO: API listening on [::]:8384
[7QCUL] 06:35:12 INFO: Local discovery over IPv6 unavailable
[7QCUL] 06:35:12 INFO: Starting global discovery announcements
[7QCUL] 06:35:12 INFO: Device 2VSZP3U-XXXXXXXXXXXXXXXXXXXXXXXXXXX-AQ2QYQB is "JonasPC" at [dynamic]
[7QCUL] 06:35:12 INFO: Device 7QCULIP-XXXXXXXXXXXXXXXXXXXXXXXXXXX-GJC57AF is "BigCloud" at [dynamic]
[7QCUL] 06:35:12 INFO: Device A7EWFMD-XXXXXXXXXXXXXXXXXXXXXXXXXXX-YAZIOA7 is "MatadorPC" at [dynamic]
[7QCUL] 06:35:12 INFO: Device EXWD3FJ-XXXXXXXXXXXXXXXXXXXXXXXXXXX-QFWMIQK is "MatadorMobile" at [dynamic]
[7QCUL] 06:35:12 INFO: Device ICX6X4Q-XXXXXXXXXXXXXXXXXXXXXXXXXXX-XGQNTQI is "MatadorSmartie" at [dynamic]
[7QCUL] 06:35:12 INFO: Device LD6BG55-XXXXXXXXXXXXXXXXXXXXXXXXXXX-PYIZ3QO is "himbeerchen" at [dynamic]
[7QCUL] 06:35:12 INFO: Device XNQRTTG-XXXXXXXXXXXXXXXXXXXXXXXXXXX-6U4UPQA is "SarahMac" at [dynamic]
[7QCUL] 06:35:12 INFO: Starting usage reporting
[7QCUL] 06:35:13 INFO: Completed initial scan (rw) of folder mp3s
this is what I got didnt produced what you expected - right?
