Syncthing running but gui not available
hi
since the last update the gui often is not available while syncthing (0.11.10) is running. memory and cpu are fine…
any ideas?
What does it mean, not available? Check the logs.
“website not available - check your internet connection” stuff… have no clue how to use stdout-is there a howto or could you tell me?
Well when you start syncthing, it logs to the window it was started from, and that’s what you should check.
syncthing isn’t started manually under shell. used a init.d script I think oO
Well check what the init.d script does with the stdout of syncthing.
I’m using a /etc/init/syncthing.conf script, which was the only that worked for me:
# /etc/init/syncthing.conf
start on (local-filesystems and net-device-up IFACE!=lo)
stop on runlevel [!2345]
env STNORESTART=yes
env USERID='syncusr'
env HOME=/home/$USERID
# setuid "syncusr"
# setgid "syncusr"
script
exec 1>>/var/log/syncthing.log 2>&1
su - $USERID -c '/usr/local/bin/syncthing'
end script
respawn
Interesting, I also have this strange bug but I thought is was something with my computer. So far I have not been able to narrow it down and there are no errors, crashes or panic logs - and: sync itselfs works as always
The only thing I can suggest is sending a SIGABRT to the process when it stops listening, and then uploading the logs to the ticket (which already exists, can’t recall the number).
Also, checking if syncthing is actually listening over netstat would be useful.
ok… will try the netstat thing… but SIGABRT? how should it be used?
It’s basically:
netstat -tulpn | grep '8080\|8384'
and
kill -6 <Syncthing pid>
which it will cause to produce a stacktrace to the log (which in your case is in /var/log/syncthing.log)
windows?
I don’t think you can do this on windows.
sounds like windows in uok’s post… mine is debian…
found something strange in var/log/syncthing.log:
2015/06/27 05:02:13 http: TLS handshake error from 109.XXX.XXX.33:32803: read tcp 109.XXX.XXX.33:32803: i/o timeout
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4136: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4137: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4138: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4140: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4144: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:29142: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:14216: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:13079: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:27004: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4145: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4146: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4147: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4148: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:18900: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:31898: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:11056: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:27769: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:7315: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:26891: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4149: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4151: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4150: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4152: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4153: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:4625: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:31073: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:18108: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:16747: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:14735: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.197:25549: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4155: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4156: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4157: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4158: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4159: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:33606: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4161: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4163: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4162: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4164: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4165: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4166: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:24201: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:7143: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:29237: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:18055: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4167: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4169: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4168: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4170: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4171: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:6249: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:15351: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:1845: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:9132: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:28158: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:31889: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4173: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4174: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4175: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4177: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4176: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4178: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4179: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4180: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4181: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4182: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4184: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4183: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4185: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4187: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4186: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4188: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4189: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4190: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4191: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4192: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4193: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4194: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4195: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4197: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4198: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4201: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4200: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4202: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4204: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4205: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:15586: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:19039: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:21657: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:24082: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:5485: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:16861: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4207: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4208: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4209: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4211: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4210: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4212: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4213: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4214: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:29185: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:3419: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:26230: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:16815: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:2244: EOF
2015/06/27 05:36:26 http: TLS handshake error from 80.XXX.XXX.60:1734: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4215: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4216: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4217: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4218: EOF
2015/06/27 05:36:26 http: TLS handshake error from 109.XXX.XXX.33:4219: EOF
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33295: read tcp 109.XXX.XXX.33:33295: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33297: read tcp 109.XXX.XXX.33:33297: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33296: read tcp 109.XXX.XXX.33:33296: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33298: read tcp 109.XXX.XXX.33:33298: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33299: read tcp 109.XXX.XXX.33:33299: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33300: read tcp 109.XXX.XXX.33:33300: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 80.XXX.XXX.197:13089: read tcp 80.XXX.XXX.197:13089: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 80.XXX.XXX.197:30745: read tcp 80.XXX.XXX.197:30745: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 80.XXX.XXX.197:28765: read tcp 80.XXX.XXX.197:28765: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 80.XXX.XXX.197:20567: read tcp 80.XXX.XXX.197:20567: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 80.XXX.XXX.197:6998: read tcp 80.XXX.XXX.197:6998: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 80.XXX.XXX.197:15418: read tcp 80.XXX.XXX.197:15418: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33607: read tcp 109.XXX.XXX.33:33607: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33610: read tcp 109.XXX.XXX.33:33610: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33614: read tcp 109.XXX.XXX.33:33614: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33613: read tcp 109.XXX.XXX.33:33613: i/o timeout
2015/06/27 05:36:36 http: TLS handshake error from 109.XXX.XXX.33:33615: read tcp 109.XXX.XXX.33:33615: i/o timeout
2015/06/27 05:36:42 http: TLS handshake error from 80.XXX.XXX.60:19714: EOF
2015/06/27 05:36:42 http: TLS handshake error from 109.XXX.XXX.33:4431: EOF
2015/06/27 05:36:57 http: TLS handshake error from 80.XXX.XXX.60:21277: EOF
2015/06/27 05:36:57 http: TLS handshake error from 80.XXX.XXX.60:2239: EOF
2015/06/27 05:36:57 http: TLS handshake error from 80.XXX.XXX.60:5904: EOF
2015/06/27 05:36:57 http: TLS handshake error from 80.XXX.XXX.60:18698: EOF
2015/06/27 05:36:57 http: TLS handshake error from 109.XXX.XXX.33:4432: EOF
2015/06/27 05:36:57 http: TLS handshake error from 109.XXX.XXX.33:4430: EOF
2015/06/27 05:36:57 http: TLS handshake error from 80.XXX.XXX.60:23991: EOF
2015/06/27 05:36:57 http: TLS handshake error from 80.XXX.XXX.60:12387: EOF
2015/06/27 05:36:57 http: TLS handshake error from 80.XXX.XXX.60:2270: EOF
2015/06/27 05:41:23 http: TLS handshake error from 80.XXX.XXX.60:13812: read tcp 80.XXX.XXX.60:13812: i/o timeout
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:23052: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4583: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4584: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4585: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4588: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4589: EOF
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:3373: EOF
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:13471: EOF
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:7841: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4591: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4592: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4593: EOF
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:18832: EOF
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:1995: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4594: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4595: EOF
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:17848: EOF
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:25934: EOF
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:30222: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4596: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4597: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4598: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4599: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4600: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4602: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4601: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4603: EOF
2015/06/27 05:52:43 http: TLS handshake error from 80.XXX.XXX.60:3663: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4604: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4605: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4607: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4611: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4609: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4610: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4608: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4613: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4614: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4615: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4617: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4616: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4618: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4619: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4620: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4621: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4622: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4623: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4625: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4624: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4627: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4626: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4629: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4628: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4630: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4631: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4632: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4633: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4634: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4635: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4636: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4637: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4639: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4638: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4640: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4641: EOF
2015/06/27 05:52:43 http: TLS handshake error from 109.XXX.XXX.33:4642: EOF
2015/06/27 06:04:19 http: TLS handshake error from 109.XXX.XXX.33:35173: read tcp 109.XXX.XXX.33:35173: i/o timeout
2015/06/27 06:04:19 http: TLS handshake error from 109.XXX.XXX.33:35174: read tcp 109.XXX.XXX.33:35174: i/o timeout
2015/06/27 06:04:19 http: TLS handshake error from 109.XXX.XXX.33:35175: read tcp 109.XXX.XXX.33:35175: i/o timeout
2015/06/27 06:04:19 http: TLS handshake error from 109.XXX.XXX.33:35176: read tcp 109.XXX.XXX.33:35176: i/o timeout
2015/06/27 06:05:06 http: TLS handshake error from 80.XXX.XXX.161:10215: read tcp 80.XXX.XXX.161:10215: i/o timeout
2015/06/27 06:05:06 http: TLS handshake error from 109.XXX.XXX.33:35369: read tcp 109.XXX.XXX.33:35369: i/o timeout
2015/06/27 06:05:06 http: TLS handshake error from 109.XXX.XXX.33:35370: read tcp 109.XXX.XXX.33:35370: i/o timeout
2015/06/27 06:17:05 http: TLS handshake error from 109.XXX.XXX.33:35845: read tcp 109.XXX.XXX.33:35845: i/o timeout
2015/06/27 06:18:01 http: TLS handshake error from 109.XXX.XXX.33:35869: read tcp 109.XXX.XXX.33:35869: i/o timeout
2015/06/27 06:23:15 http: TLS handshake error from 109.XXX.XXX.33:5167: EOF
2015/06/27 06:23:15 http: TLS handshake error from 109.XXX.XXX.33:5169: EOF
2015/06/27 06:23:15 http: TLS handshake error from 109.XXX.XXX.33:5168: EOF
2015/06/27 06:23:15 http: TLS handshake error from 109.XXX.XXX.33:5170: EOF
2015/06/27 06:23:26 http: TLS handshake error from 109.XXX.XXX.33:35935: read tcp 109.XXX.XXX.33:35935: i/o timeout
2015/06/27 06:23:26 http: TLS handshake error from 109.XXX.XXX.33:35936: read tcp 109.XXX.XXX.33:35936: i/o timeout
2015/06/27 06:29:07 http: TLS handshake error from 109.XXX.XXX.33:35985: read tcp 109.XXX.XXX.33:35985: i/o timeout
2015/06/27 06:29:07 http: TLS handshake error from 109.XXX.XXX.33:35982: read tcp 109.XXX.XXX.33:35982: i/o timeout
2015/06/27 06:29:07 http: TLS handshake error from 109.XXX.XXX.33:35984: read tcp 109.XXX.XXX.33:35984: i/o timeout
2015/06/27 06:34:58 http: TLS handshake error from 109.XXX.XXX.33:36187: read tcp 109.XXX.XXX.33:36187: i/o timeout
2015/06/27 06:34:58 http: TLS handshake error from 109.XXX.XXX.33:36188: read tcp 109.XXX.XXX.33:36188: i/o timeout
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5822: EOF
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5823: EOF
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5821: EOF
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5824: EOF
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5825: EOF
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5827: EOF
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5828: EOF
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5826: EOF
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5829: EOF
2015/06/27 07:04:28 http: TLS handshake error from 109.XXX.XXX.33:5830: EOF
2015/06/27 07:39:19 http: TLS handshake error from 109.XXX.XXX.33:38035: read tcp 109.XXX.XXX.33:38035: i/o timeout
You have https enabled and you or someone is trying to access the site via http.
true… that’s me :smile: but what does the errors say? before 11.10 I had this error too but not as often as now.
You have https enabled and you or someone is trying to access the site via http., though that should be handled, its failing to get past the TLS handshake basically.
ok got this… means, this is the reason why I can’t access the gui… right?
It should work if you use https://localhost:8080 (or port 8384).
