Safely move synchronized folder
Hi all,
I am rather paranoid about manually moving my synchronized folder (“sync target”) and then re-establishing synchronization between the sync source and that moved target folder. Specifically, I need to move my synchronized folder to another hard drive.
There’s already some threads about it, however I’m not entirely sure which way to go:
As far as I know, for example, the date of file folders is changed by Windows when they are moved, to the time they were moved, at least when moving to another hard drive.
Now I’m afraid that this will cause folders and possibly also files from the synchronization target to be overwritten in the synchronization source, because the target suddenly contains thousands of apparently brand-new folders.
Many thanks for all ideas on how to move a synchronized folder (sync target) so that there is no risk of damaging the sync source, especially not by mass-overwriting it with files/folders from the target.
As you yourself point out this has been answered multiple times. If you are in sync before this maneuver there should be no risk of things being overwritten, as they are already the same.
Thanks Jakob,
…“should” is still too risky for me in this case, because the source folder is on a c*mpany server and absolutely must not be damaged.
So are you saying that even when all (thousands) of the target folder dates are changed to “today” by moving the target folder, Syncthing will still not overwrite the source folders?
Syncthing doesn’t sync directory times, and I’m not sure what overwriting a directory precisely means to begin with.
But:
Clearly you must have excellent backups of this folder in triplicate, so do whatever and trust the backups to sort you out if something goes wrong. :wink:
You also have the send-only folder type which is your friend. Use that on the valuable server side.
Thank you.
Do you know of any setting or recommended setup between the “send-only folder type” and “full mass deletion risk” on the source folder (apart from versioning) – that I could use?
