Hi, I need some assistance, I have 2 servers syncing but one of the servers is reporting that the remote server is out-of-sync when it isn’t.
What I have tried:
Restart both Syncthing services
Shutdown both Syncthing services
Checked Advanced settings
Here are screenshots of both servers:
Thanks in advance!
uok
(uok)
December 4, 2020, 6:32pm
2
It is possible that this is because of a known bug which will be fixed in the next version.
Problem is I already tried restarting both STs and even tried shutting them down…
Andy
(Andreas Kaelber)
December 4, 2020, 8:30pm
4
I have the same on my Synology Servers and step back to v1.10.0 and also on all my clients. This runs very good.
Because of the Bug among other tomorrow is coming v1.12.1 in which the stuck issue is solved. I will test that version.
uok
(uok)
December 4, 2020, 8:31pm
5
you could take a few example files and test with checksums if they are identical.
I will wait for tomorrow’s version, since I am running it on unRAID, the “shutdown” doesn’t really shut down, it’s a docker. So I am assuming when a new version gets installed it will “shutdown” and the new version boot up. (Fingers crossed)
Thank you for pointing this bug out.
Andy
(Andreas Kaelber)
December 5, 2020, 12:16pm
7
is changed
so we wait for that release v1.12.1
calmh
(Jakob Borg)
December 5, 2020, 2:25pm
8
Nothing has changed in the release schedule.
Andy
(Andreas Kaelber)
December 5, 2020, 3:36pm
9
That may be. I thought it was 2020-12-05. But the current is also okay. Affected people can do it as long as I doe, that’s a working solution.
tomasz86
(Tomasz Wilczyński)
December 5, 2020, 3:37pm
10
calmh:
Just a very minor side note, but it would be nice to have some kind of a time zone indication there. Here it always seems to already be the next they when a new release is up .
calmh
(Jakob Borg)
December 5, 2020, 9:29pm
11
0.12.0 was released 2020-12-01, as scheduled. The next release follows a month later, always on the first Tuesday of the month.
Releases are usually made between 07:00 and 23:00 UTC, roughly coinciding with waking hours in my home time zone.
