I’m running syncthings v0.10.11 on a Synology DS214+ (1.33GHz dual core armv7 ArmadaXP CPU & 1GB RAM) using the package found on the cytec.us repository : this is my “master-folder”, let’s call it machine A.
I’m also running the same synology package on a DS214play (1.6GHz dual core i686 Intel Atom CE5335 CPU & 1GB RAM), let’s call it machine B.
I already have a folder that is both on machine A and B (original sync done with rsync), that contains mainly videos of 700MB per file, for a total of 512GB od fata in 769 files and 476 folders.
I have setup the folder to be “Folder Master” on machine A and not on machine B.
After over 2 days of letting the 2 machines do only the sync (no other activity on the machines), I find that the folder is still beeing synced, and the machine A seems to be stuck at “500 items, ~175 GiB” when looking at the web-GUI. (I’ve been trying to minimize use of the GUI since I understood it puts extra load on the machine…)
Still in the GUI, syncthings is using a lot of ressources :
Download Rate 0 B/s (91.5 MiB)
Upload Rate 0 B/s (27.1 MiB)
RAM Utilization 986 MiB
CPU Utilization 155%
Global Discovery OK
Version v0.10.11
I’ve seen the RAM usage go over 1GB (wich did not seem right given the machine only has 1GB…)
When digging a little, I found that there is alot of “panic” logs in the var folder… Both on machine A and B…
- Here is a list of the files inside the var folder on machine A : http://pastebin.com/X1YnwRxE
- Here is the content of the panic-20141210-190739.log on machine A : http://pastebin.com/9m80LZJA (I’ve picked a date a while back since I’m currently tryng to sync other things between machine B and machine C, so this is the logs from a time where only A and B where syncyng…)
- Here is a list of the files inside the var folder on machine B : pastebin : R0QtrbHr
- Here is the content of the panic-20141210-192422.log file on machine B : pastebin : FLd0VyQ7 (I’m a new user, so I can’t add so many pastebin links, just copy/paste the ident in bolg after the pastebin url.)
I realy don’t understand these panic logs, and I don’t understand why it takes so much memory… It would be great if someone could help me find out what to do to finally be able to sync this folder that it taking days to be scanned and seems to ne be making progress for about 1 day now…
Thank you in advance
