Error when starting Syncthing
At first, I didn’t figure out what to download Synching or SyncTrayzor. As I understood at the end, I need exactly SyncTrayzor, but at the moment it gives an error when starting. What is written in the error:
Failed to start Syncthing. Please read the log to determine the cause. If “FATAL: Cannot open database” appears, please close any other open instances of Syncthing. If SyncTrayzor crashed previously, there may still be zombie Syncthing processes alive. Please use the menu option “Syncthing → Kill all Syncthing processes” to stop them, then use “Syncthing → Start” to start Syncthing again.
I tried to Kill all Syncthing processes, but the error still appears. [monitor] 14:08:13 INFO: Log output saved to file “C:\Users\as960\AppData\Local\Syncthing\syncthing.log” [start] 14:08:13 INFO: syncthing v1.18.1 “Fermium Flea” (go1.16.6 windows-amd64) teamcity@build.syncthing.net 2021-07-30 12:41:57 UTC [start] 14:08:13 WARNING: Failed to initialize config: config file version (37) is newer than supported version (35). If this is expected, use -allow-newer-config to override.
Please tell me how to fix it?
