Clients that used to work perfectly always show “disconnected”. Please tell me what I am doing wrong. Thank you.
The logs are edited slightly. I added space characters to disable link detection.
BFMartin
On the OpenBSD side, here is the log file:
[JGMWN] 21:01:37 INFO: syncthing v0.14.17 “Dysprosium Dragonfly” (go1.8beta2 openbsd-amd64) jenkins@build.syncthing.net 2016-12-27 10:29:12 UTC [JGMWN] 21:01:37 INFO: My ID: JGMWNK7-WKSLGF2-MSFDGJQ-I3DX4SJ-DDUZKUI-HQJ4Q3N-3THBEYB-DA6FUQ6 [JGMWN] 21:01:38 INFO: Single thread hash performance is 158 MB/s using minio/sha256-simd (130 MB/s using crypto/sha256). [JGMWN] 21:01:38 INFO: Ready to synchronize “bfm” (jdahr-mox7l) (readwrite) [JGMWN] 21:01:38 INFO: Using discovery server https : //discovery-v4-2.syncthing.net/v2/?id=DVU36WY-H3LVZHW-E6LLFRE-YAFN5EL-HILWRYP-OC2M47J-Z4PE62Y-ADIBDQC [JGMWN] 21:01:38 INFO: Using discovery server https : // discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3-VVMM66S-HRVWSCR-IXEHL2H-U4AQ4MW-UCPQBWX-J2L2UBK-NVZRDQZ [JGMWN] 21:01:38 INFO: Using discovery server https : //discovery-v4-4.syncthing.net/v2/?id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW [JGMWN] 21:01:38 INFO: Using discovery server https : // discovery-v6-2.syncthing.net/v2/?id=DVU36WY-H3LVZHW-E6LLFRE-YAFN5EL-HILWRYP-OC2M47J-Z4PE62Y-ADIBDQC [JGMWN] 21:01:38 INFO: Using discovery server https : // discovery-v6-3.syncthing.net/v2/?id=VK6HNJ3-VVMM66S-HRVWSCR-IXEHL2H-U4AQ4MW-UCPQBWX-J2L2UBK-NVZRDQZ [JGMWN] 21:01:38 INFO: Using discovery server https : // discovery-v6-4.syncthing.net/v2/?id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW [JGMWN] 21:01:38 INFO: TCP listener (0.0.0.0:22000) starting [JGMWN] 21:01:38 INFO: Completed initial scan (rw) of “bfm” (jdahr-mox7l) [JGMWN] 21:01:38 INFO: Device JGMWNK7-WKSLGF2-MSFDGJQ-I3DX4SJ-DDUZKUI-HQJ4Q3N-3THBEYB-DA6FUQ6 is “drathro.bfm.ca” at [dynamic] [JGMWN] 21:01:38 INFO: Device YLMI2X4-EJKMBPP-JKCBZOE-UQRD7HB-357FI5W-OUEDHXI-BRAVH35-6UJ3OA4 is “s4phone” at [dynamic] [JGMWN] 21:01:38 INFO: GUI and API listening on 192.168.3.5:8443 [JGMWN] 21:01:38 INFO: Access the GUI via the following URL: https : // drathro.bfm.ca:8443/ [JGMWN] 21:01:38 INFO: c.S.listenerSupervisor: Failed service ‘dynamic+https : // relays.syncthing.net/endpoint’ (1.000000 failures of 2.000000), restarting: true, error: “{dynamic+https : // relays.syncthing.net/endpoint dynamic+https : // relays.syncthing.net/endpoint} returned unexpectedly”, stacktrace: [unknown stack trace] [JGMWN] 21:01:38 INFO: c.S.listenerSupervisor: Failed service ‘dynamic+https : // relays.syncthing.net/endpoint’ (1.994699 failures of 2.000000), restarting: true, error: “{dynamic+https : // relays.syncthing.net/endpoint dynamic+https : // relays.syncthing.net/endpoint} returned unexpectedly”, stacktrace: [unknown stack trace] [JGMWN] 21:01:39 INFO: Entering the backoff state. [JGMWN] 21:01:39 INFO: c.S.listenerSupervisor: Failed service ‘dynamic+https : // relays.syncthing.net/endpoint’ (2.981990 failures of 2.000000), restarting: false, error: “{dynamic+https : // relays.syncthing.net/endpoint dynamic+https : // relays.syncthing.net/endpoint} returned unexpectedly”, stacktrace: [unknown stack trace]
On the Android side:
--------- beginning of main 12-28 16:55:21.955 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:22.065 V/RestTask(18912): Calling Rest API at https : // 127.0.0.1:8384 12-28 16:55:22.065 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:22.065 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:22.165 V/RestTask(18912): Calling Rest API at https : // 127.0.0.1:8384 12-28 16:55:22.165 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:22.165 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:22.275 V/RestTask(18912): Calling Rest API at https : // 127.0.0.1: 8384 12-28 16:55:22.275 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:22.275 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:22.385 V/RestTask(18912): Calling Rest API at https : // 127.0.0.1:8384 12-28 16:55:22.385 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:22.385 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:22.486 V/RestTask(18912): Calling Rest API at https : // 127.0.0.1:8384 12-28 16:55:22.496 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:22.496 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:22.596 V/RestTask(18912): Calling Rest API at https : // 127.0.0.1:8384 12-28 16:55:22.596 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:22.596 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:22.646 I/SyncthingRunnableIoNice(18912): ionice performed on libsyncthing.so 12-28 16:55:22.706 V/RestTask(18912): Calling Rest API at https : // 127.0.0.1:8384 12-28 16:55:22.706 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:22.706 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:22.806 V/RestTask(18912): Calling Rest API at https : // 127.0.0.1:8384 12-28 16:55:22.806 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:22.816 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:22.906 I/SyncthingNativeCode(18912): [YLMI2] 21:55:22 INFO: Single thread hash performance is 27 MB/s using minio/sha256-simd (26 MB/s using crypto/sha256). 12-28 16:55:22.916 V/RestTask(18912): Calling Rest API at https : // 127.0.0.1:8384 12-28 16:55:22.916 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:22.916 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:23.026 V/RestTask(18912): Calling Rest API at https : //127.0.0.1:8384 12-28 16:55:23.026 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:23.026 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:23.076 I/SyncthingNativeCode(18912): [YLMI2] 21:55:23 INFO: Ready to synchronize sgh-i337m-photos (readonly) 12-28 16:55:23.086 I/SyncthingNativeCode(18912): [YLMI2] 21:55:23 INFO: Using discovery server https : // discovery-v4-2.syncthing.net/v2/?id=DVU36WY-H3LVZHW-E6LLFRE-YAFN5EL-HILWRYP-OC2M47J-Z4PE62Y-ADIBDQC 12-28 16:55:23.086 I/SyncthingNativeCode(18912): [YLMI2] 21:55:23 INFO: Using discovery server https : // discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3-VVMM66S-HRVWSCR-IXEHL2H-U4AQ4MW-UCPQBWX-J2L2UBK-NVZRDQZ 12-28 16:55:23.096 I/SyncthingNativeCode(18912): [YLMI2] 21:55:23 INFO: TCP listener ([::]:22000) starting 12-28 16:55:23.146 V/RestTask(18912): Calling Rest API at https : //127.0.0.1:8384 12-28 16:55:23.146 I/System.out(18912): (HTTPLog)-Static: isSBSettingEnabled false 12-28 16:55:23.166 I/System.out(18912): KnoxVpnUidStorageknoxVpnSupported API value returned is false 12-28 16:55:23.186 I/SyncthingNativeCode(18912): Using DNS servers: [2607:f798:18:10:0:640:7125:5254:53 2607:f798:18:10:0:640:7125:5253:53] 12-28 16:55:23.186 I/SyncthingNativeCode(18912): [YLMI2] 21:55:23 INFO: c.S.listenerSupervisor: Failed service ‘dynamic+https : // relays.syncthing.net/endpoint’ (1.000000 failures of 2.000000), restarting: true, error: “{dynamic+https : // relays.syncthing.net/endpoint dynamic+https : // relays.syncthing.net/endpoint} returned unexpectedly”, stacktrace: [unknown stack trace]
