v1.26.0
Note new login behavior.
Early release because I’m offline Tuesday.
This release brought to you from Honolulu airport.
Bugfixes
- #9072: Omitting %s from LDAP search filter results in corrupt search filter
- #9106: Posting config with invalid versioner type causes panic
- #9120: Deduplicated files on Windows aren’t treated as regular files any more (Go 1.21)
- #9133: Syncthing Docker container fails to start if underlying filesystem doesn’t support
chown - #9143: traefik no longer url escape X-Forwarded-Tls-Client-Cert header
- #9149: Favicon is stuck in notify state
Enhancements
- #4137: Use a real login screen + sessions instead of HTTP basic auth
