Syncthing 2.0.0-rc.16
Trying to figure out a good way for macOS users to test this. Should we just replace our syncthing binary inside the 1.29.6 app bundle?
You can try it. Personally I run it from launchd without the GUI, so I’m not sure. :person_shrugging:
Works for me on the pi 1, thx
Today, on one device after rebooting the OS and starting Syncthing in the process, I’m experiencing the Web GUI being completely stalled:
It has been in this state for ~40 minutes or so, and the device in question appears disconnected on other devices. The hardware is decent, and normally everything works just fine.
I’m uploading a full goroutine dump below. I also wanted to take CPU and heap profiles, but I cannot, as the browser just keeps trying to load the /rest/debug/heapprof URLs (as by https://docs.syncthing.net/users/profiling.html) with no end to it.
The log is also basically flooded with these:
[3KHRD] 2025/05/24 18:57:35 INFO: Listen (BEP/tcp): TLS handshake: read tcp 192.168.50.253:22000->192.168.50.1:22000: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 18:59:51 INFO: Listen (BEP/tcp): TLS handshake: read tcp 192.168.50.253:22000->192.168.50.1:1139: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 19:00:06 INFO: Listen (BEP/tcp): TLS handshake: read tcp 192.168.50.253:22000->192.168.50.1:1139: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 19:00:20 INFO: Listen (BEP/tcp): TLS handshake: read tcp [fe80::d5c2:2f0d:e1d2:13ce%Wi-Fi 4]:22000->[fe80::2c0a:f886:fe67:b899%Wi-Fi 4]:60859: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 19:01:06 INFO: Listen (BEP/tcp): TLS handshake: read tcp 192.168.50.253:22000->192.168.50.1:22000: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 19:02:26 INFO: Listen (BEP/tcp): TLS handshake: read tcp 192.168.50.253:22000->192.168.50.1:22000: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 19:02:37 INFO: Listen (BEP/tcp): TLS handshake: read tcp 192.168.50.253:22000->192.168.50.1:1139: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 19:03:51 INFO: Listen (BEP/tcp): TLS handshake: read tcp [fe80::d5c2:2f0d:e1d2:13ce%Wi-Fi 4]:22000->[fe80::2c0a:f886:fe67:b899%Wi-Fi 4]:22000: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 19:04:57 INFO: Listen (BEP/tcp): TLS handshake: read tcp 192.168.50.253:22000->192.168.50.1:22000: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 19:06:22 INFO: Listen (BEP/tcp): TLS handshake: read tcp [fe80::d5c2:2f0d:e1d2:13ce%Wi-Fi 4]:22000->[fe80::2c0a:f886:fe67:b899%Wi-Fi 4]:60882: wsarecv: An existing connection was forcibly closed by the remote host.
[3KHRD] 2025/05/24 19:08:53 INFO: Listen (BEP/tcp): TLS handshake: read tcp 192.168.50.253:22000->192.168.50.1:22000: wsarecv: An existing connection was forcibly closed by the remote host.
This is Windows 11 x64, and Syncthing has been built from https://github.com/tomasz1986/syncthing/tree/tomasz86/releases/tomasz86-v2.0.0-rc.16.
I’d be very grateful if you could have a look at the goroutine dump and let me know if there is anything obvious in there :downcast_face_with_sweat:.
Edit:
I had to bring the device back to life, so I just killed the Syncthing process and restarted it. After doing so, it launched and began to sync as usual, so I’m really not sure what had happened before…
Fiddled around a bit, as I definitely wanted to test this on macOS before 2.0 goes final. But, no matter what, syncthing kept crashing.
Finally figured out the problem—the wrapper was still using the old single-dash longopts.
I updated my build script to fix this, and it mints a properly-codesigned 2.0-rc.16 macOS app bundle.
I also just submitted PR#249 to syncthing-macos @xor-gate
Otherwise, so far so good :+1: — hopefully this helps the next brave adventurer.
This docker image gives a manifest error. Is there a new one?
ghcr.io/syncthing/syncthing:v2.0.0-beta.16
Yes, works. Thanks for the quick reply. Maybe someone can edit the first message here to fix.
That would be 2.0.0-rc.16, not v2.0.0-beta.16.
See Syncthing 2.0.0-rc.16 - #30 by marbens.
Debian worked fine. I need windows and macos builds. I guess is ok to run mixed old/new for a bit?
If you mean mixing v1 and v2 devices in a cluster, that should work fine.
Also there are of course Windows and macOS builds linked.
Official Syncthing for macOS bundle and status icon has a v2 branch and first bundled pre-release. Lets see how far we can go. I’m not going to test this on my production systems and data just yet. Release Syncthing for macOS v2.0.0-rc.16+1 · syncthing/syncthing-macos · GitHub
@xor-gate thank you for the build, just curious why you chose these words: “Initial release which bundles the upcoming incompatible v2” – what is incompatible? I tested v2 syncing with two v1 nodes and it worked fine. Are you talking about the db change from Level to sqlite?
I’m not very active about the discussion on v2, but v1 and v2 are major version bumps. Probably in the future the API is incompatible. I wanted to be on the safe side beforehand.
Receive-encrypted folders are showing out-of-sync 95% 0B after files are deleted on one side.
Fuller explanation: two Linux laptop and RPi4 share a folder. The Pi has this folder receive-encrypted the two laptop are send-receive.
Laptop A will fully sync with the Pi. Later, with laptop A disconnect, laptop B comes online to share data from the Pi, which results in out-of-sync 95% 0B on laptop B for a few files that were deleted earlier by laptop A.
This is resolved if the data on the Pi is removed and re-synced as send-receive.
I didn’t take a screenshot of the out-of-sync state on laptop B before resolving the issue with send-receive, sorry.
Edit: To be clear, the two laptop share the folder in send-receive mode and share with the RPi4 as receive-encrypted. This arrangement worked flawlessly with v1.
Edit 2: I suspect the files involved were all 0 byte cache files deleted on laptop A, synced to RPi4 but not updated/cleared from the database on laptop B.
All is well again with rc.17. Thanks to @calmh
I don’t really think anything changed on that front. I couldn’t reproduce the issue.
Sorry, been away for a long weekend. This is not unique to v2. It’s been an occasional issue on 2 x remote computers for several months on v1. When it appears, I simply restart St. I put it down to Synctrazor compatibility
I doubt it’s a Synctrayzor thing, though it could be that it just takes a long time to load folder data when there’s a lot of them…?
