I sync from MAC (M2, 32 Gig) to a raspberry Pi 5 (8 Gig).
after some hours, the speed goes down from (just now as example) “2,21 MiB/s (3,1 GiB)” to at about 200…500K.
When I restart both sides via WEB-insterface, the speed immediately goes up again to previous level.
Background:
on both sides the disks are USB-3-connected.
Connection between the 2 computers is WLAN.
versions
raspberryPi: syncthing v1.27.3, Linux (64-bit ARM)
OS “Debian GNU/Linux 12 (bookworm)”
HW Raspberry Pi 5 Model B Rev 1.0
MAC: syncthing v1.27.2, macOS (64-bit ARM)
OS Ventura, 13.6.4
HW Apple M2 Pro
history
on “raspi-side” I recently switched from raspi 4B → raspi 5 (see above).
because of many files (~2…3 TB) I keept the files on “raspi-side” and now (try to) re-sync …
Also watch out for the CPU temperature on the raspi. If heavy hashing or encryption is involved, it might be throttling down because it gets hotter by the minute.
I think, you’re right …
it might be NOT a syncthing problem…
(I forgot to mention: I boot the raspi from usb disk, data is on a different disk, not the same, so hopefully the SD-card should not be involved in my case …)
temperatur: values : (last 2 days)
54.3°C … 67.5°C
55.4°C … 68.6°C
→ might this be a problem?
(I did not find reliable values for “too high” temperatures…
found somthing ~80°C, but from my point of view -gut feeling- thats MUCH too high …
what do you think?
I stopped syncthing and tried to transfer my data from mac to raspi
via “rsync -av…”.
→ I found the same reaction: it started quickly, slowed down over night…
so it could be a “local raspi-problen”
