thanks for this great project and I’m here to share my solution to get Synology photos auto index working with syncthing.
So I have 2 Synology nas, need to sync files between them. Was using Synology drive share sync, buggy and painfully slow. Switched to syncthing in dockers and it’s so much better user experience/performance.
But photo files synced via syncthing is not showing up in Synology photos. I have to manually trigger reindex for them to show up.
Tried some solution like letorbi/synoindexwatcher and didn’t work, but I found some useful infomation here: DSM7 (Synology Photo) compatibility · Issue #51 · letorbi/synoindexwatcher · GitHub
Reason for the issue being:
The process which listens for changes, and activates the auto indexing service does not directly monitor the disc for file changes. It instead communicates with other services to determine when a change is made, and then activates the indexing process. Unfortunately, changes to the disk via docker is not one of the things this process currently monitors.
Synology photos monitor file updated via smb and other regular protocols but not via direct mounted docker.
I got it working by mount the Synology path as a local smb volume instead of direct mount, so that the triffic is treated as smb operations.
sample docker compose:
version: '3'
services:
syncthing:
image: syncthing/syncthing:latest
container_name: syncthing-syncthing-compose
volumes:
- photo:/photo
- homes:/homes
environment:
- PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
- PUID=0
- PGID=0
- HOME=/var/syncthing
- STGUIADDRESS=0.0.0.0:8384
- STHOMEDIR=/var/syncthing/config
network_mode: host
ports:
- "21027/udp"
- "22000/tcp"
- "22000/udp"
- "8384/tcp"
volumes:
homes:
driver_opts:
type: cifs
o: iocharset=utf8,username=<smb_username>,password=<smb_password>,vers=3.0
device: //127.0.0.1/homes
photo:
driver_opts:
type: cifs
device: //127.0.0.1/photo
This can be a solution for all issues caused by Synology won't auto index my file created via docker, I’ve seen people talk about it in the radarr/sonarr community.
It works with 2 caveats:
- seems only working with docker PID=0. otherwise I’m having permission denied. But the updated file come with owner of the smb user instead of root.
- as was mentioned 3 years ago by @calmh : SMB share of Syncthing folder? - #2 by calmh
When Syncthing is accessing a folder over SMB it needs to rely on periodic scans instead of change notifications. Changes still get picked up, but with slightly higher latency.
It’s not a real time syncing experience , need to wait for the interval scan to pickup new changes, but toally acceptable to me. Is it possible to get real time notifications over SMB now? Didn’t find much docs about this topic.
Hope this helps you if you are also having this problem, and let me know if the 2 caveats can somehow be solved. Cheers!
