At some point in the last week, my settings dialog started displaying missing values for several fields, though I never changed them. Everything is behaving as it was when the settings were displaying correctly, but the fields are blank.
My main indicator is that upload bandwidth is still limited to 100KB/s.
I suppose I can muck around in the settings files, but I’d love to continue using the GUI to make changes. I’m just wondering if maybe my settings are corrupt and the GUI is punting or what. Setting the values and saving did not “stick” for very long.
Here is a sanitized version of my config.xml (that appears to be valid XML):
<configuration version="20">
<folder id="*" label="*" path="*" type="readwrite" rescanIntervalS="3600" ignorePerms="false" autoNormalize="true">
<device id="*" introducedBy=""></device>
<minDiskFree unit="%">1</minDiskFree>
<versioning type="staggered">
<param key="cleanInterval" val="3600"></param>
<param key="maxAge" val="2592000"></param>
<param key="versionsPath" val=""></param>
</versioning>
<copiers>0</copiers>
<pullers>0</pullers>
<hashers>0</hashers>
<order>alphabetic</order>
<ignoreDelete>false</ignoreDelete>
<scanProgressIntervalS>0</scanProgressIntervalS>
<pullerSleepS>0</pullerSleepS>
<pullerPauseS>0</pullerPauseS>
<maxConflicts>10</maxConflicts>
<disableSparseFiles>false</disableSparseFiles>
<disableTempIndexes>false</disableTempIndexes>
<fsync>true</fsync>
<paused>false</paused>
<weakHashThresholdPct>25</weakHashThresholdPct>
</folder>
<folder id="*" label="*" path="*" type="readwrite" rescanIntervalS="14400" ignorePerms="false" autoNormalize="true">
<minDiskFree unit="%">10</minDiskFree>
<versioning></versioning>
<fsync>true</fsync>
</folder>
<folder id="*" label="*" path="*" type="readonly" rescanIntervalS="14400" ignorePerms="false" autoNormalize="true">
</versioning>
<fsync>true</fsync>
</folder>
</versioning>
<fsync>true</fsync>
</folder>
<device id="*" name="*" compression="metadata" introducer="false" skipIntroductionRemovals="false" introducedBy="">
<address>dynamic</address>
</device>
</device>
</device>
<gui enabled="true" tls="true" debugging="false">
<address>0.0.0.0:8384</address>
<user>*</user>
<password>*</password>
<apikey>*</apikey>
<theme>default</theme>
</gui>
<options>
<listenAddress>default</listenAddress>
<globalAnnounceServer>default</globalAnnounceServer>
<globalAnnounceEnabled>true</globalAnnounceEnabled>
<localAnnounceEnabled>true</localAnnounceEnabled>
<localAnnouncePort>21027</localAnnouncePort>
<localAnnounceMCAddr>*</localAnnounceMCAddr>
<maxSendKbps>100</maxSendKbps>
<maxRecvKbps>1500</maxRecvKbps>
<reconnectionIntervalS>60</reconnectionIntervalS>
<relaysEnabled>true</relaysEnabled>
<relayReconnectIntervalM>10</relayReconnectIntervalM>
<startBrowser>false</startBrowser>
<natEnabled>true</natEnabled>
<natLeaseMinutes>60</natLeaseMinutes>
<natRenewalMinutes>30</natRenewalMinutes>
<natTimeoutSeconds>10</natTimeoutSeconds>
<urAccepted>-1</urAccepted>
<urUniqueID></urUniqueID>
<urURL>https://data.syncthing.net/newdata</urURL>
<urPostInsecurely>false</urPostInsecurely>
<urInitialDelayS>1800</urInitialDelayS>
<restartOnWakeup>true</restartOnWakeup>
<autoUpgradeIntervalH>0</autoUpgradeIntervalH>
<upgradeToPreReleases>false</upgradeToPreReleases>
<keepTemporariesH>24</keepTemporariesH>
<cacheIgnoredFiles>false</cacheIgnoredFiles>
<progressUpdateIntervalS>5</progressUpdateIntervalS>
<limitBandwidthInLan>false</limitBandwidthInLan>
<minHomeDiskFree unit="%">1</minHomeDiskFree>
<releasesURL>https://upgrades.syncthing.net/meta.json</releasesURL>
<overwriteRemoteDeviceNamesOnConnect>false</overwriteRemoteDeviceNamesOnConnect>
<tempIndexMinBlocks>10</tempIndexMinBlocks>
<trafficClass>0</trafficClass>
<weakHashSelectionMethod>auto</weakHashSelectionMethod>
<stunServer>default</stunServer>
<stunKeepaliveSeconds>24</stunKeepaliveSeconds>
<defaultKCPEnabled>false</defaultKCPEnabled>
<kcpNoDelay>false</kcpNoDelay>
<kcpUpdateIntervalMs>25</kcpUpdateIntervalMs>
<kcpFastResend>false</kcpFastResend>
<kcpCongestionControl>true</kcpCongestionControl>
<kcpSendWindowSize>128</kcpSendWindowSize>
<kcpReceiveWindowSize>128</kcpReceiveWindowSize>
<minHomeDiskFreePct>0</minHomeDiskFreePct>
</options>
</configuration>
