Manually Configure Device ID?
Hello:
I suspect I already know the answer to this - but I’ll ask just in case I’m wrong…
Is it possible to manually set the ID of a device?
I recently lost the configuration folder for a machine, so I need to re-set it up. Ideally I would like to manually set the device ID to its previous ID, rather than having to re-pair all the other devices in the cluster with a new ID.
Looking at the documentation, it appears the device ID is derived from the certificate pair - so I’m not going to be able to manually configure it.
Is that right?
Many thanks!
Yeah, that is impossible. You may want to also check https://forum.syncthing.net/t/my-syncthing-device-id-changed-after-a-bsod-config-lost/7312.
For the repairing with a lot of devices, you could perhaps use https://docs.syncthing.net/users/introducer.html.
Thanks @tomasz86 - I didn’t find that thread!
Kinda glad to have my thoughts confirmed; unfortunately I can’t use the introducer in this cluster (some folders are only shared with some devices…) - but it’s not going to be a complete pain, as I have most of the configuration details documented elsewhere.
In future, consider having Syncthing sync its own config to a trusted machine. At least if it goes BSOD or HDD/SSD dies the config is recoverable. See:
Be sure to keep those files secure or anyone else can impersonate you/your server.
