How to UN-'Ignoring folder "foo" from device "bar"'
Hello, by accident I ignored folder “foo” from device “bar”. How can I undo this?
I’ve already deactivated the sync via Edit > Shared with devices on both sides and reactivated it. Also delete folder on the ignoring end and recreating and sharing it. Searched for an answer here and found many .stignore-related posts but no help for the GUI. Any chance?
Thanks very much in advance.
There is a bug which causes once ignored folders to stay ignored, even if added manually. You probably have to update to the rc version for the fix, or wait ~2weeks: https://github.com/syncthing/syncthing/releases/tag/v0.14.32-rc.1
Thanks wweich! Yes! Worked! Great!
