How to set up on USB ethernet (without WiFi)?
I found some old post that didn’t answer my question (Sync over "ethernet" only (actually over USB)) so I’m starting a new one.
Fresh install, Android 12, USB stick ethernet adapter, wifi disabled. Every other app works fine over ethernet, Syncthing displays an error that reads “Syncthing is disabled. Do you want to change run conditions? Reason: No network […]”
Is there anything I can do to workaround it?
I haven’t tested this myself, but what if you go to the run condition settings and enable running in airplane mode?
