You should clarify what you are looking a comment on, given this thread is quite lenghty.
What is the correct setting and in which place?
Also, just in case, you can do Start → Run → rundll32.exe sysdm.cpl,EditEnvironmentVariables.
It works fine with Windows 11 as well. Otherwise I would have been surprised, the basis is Windows 10/8. The error was that I first had an installation with “STNOUPGRADE” = 1 and did not reinstall the MSI before using the MSI with “STNOUPGRADE” = 0.
