CLI Features implemented in GUI
Not all platforms react in the same way to CLI commands.
While e.g. in Windows, among other things, the CLI parameter -reset-deltas reacts as expected, the process reacts only to a limited extent in other environments. If this e.g. run on a Synology in this way as
/var/packages/syncthing.net/target/bin/syncthing -reset-deltas
Although the process starts, it does not work as required, even if the syncthing process is stopped. Such differences also lead to uncertainty when the processes show up differently.
The feature request would be that all CLI functions are integrated into the GUI so that their correct and efficiently usable functionality is given. This would also simplify the support.
How so?
Probably because it runs with a different user and home directory when run by the actual start script, so what he does on the command line as another user has no effect.
Is difficult for me to see the effect of that circumstances. During my activities on Synology the command line user is root and not syncthing.net
For a -reset-deltas I stop the service and start with syncthing -reset-deltas. On Windows e.g. with
C:\Program Files\Syncthing\syncthing.exe -reset-deltas
I can then observe that the GUI reactivates and the processes work differently than in normal operation. The CMD also cooperates in a traceable manner in parallel.
If I do the same with a Synology, there is no interaction. There are also no noticeable changes, as is the case with Windows when there is an error.
Well, if there’s a start-up script running Syncthing as a special user, you’ll need to run as that user, too. At least it sounds like it isn’t doing user namespacing…
On Synology I can Syncthing manually start, stop, restart with the synoservicecfg command. E,g, start with
synoservicecfg --start pkgctl-syncthing.net
If I try to start --reset-deltas in that way
synoservicecfg --start pkgctl-syncthing.net --reset-deltas
it doesnt run. What is wrong?
You can’t pass application arguments to package manager command, the two are unrelated, and that will never work.
The question is what is the solution for such cases.
If I don’t start Syncthing via the package service, and want to start the binary directly
/volume1/@appstore/syncthing.net/bin/syncthing --reset-deltas
the productive database is not addressed, but a new one is created under
/volume1/@appstore/syncthing.net/.config/syncthing/index-v0.14.0.db/
However, the existing one is located under
/volume1/syncthing-data/index-v0.14.0.db/
which of course is not addressed.
Then you need to specify the --home option in addition.
That works … :sunglasses:
