Hey Syncthing Team,
I’m a long-time Syncthing user and fan. I’m trying to deepen my understanding of the system so I can rely on it for more of my data, and I’ve been wondering about how sync works in different situations.
Syncthing’s FAQ answers “What if there is a conflict?”:
Syncthing does recognize conflicts. When a file has been modified on two devices simultaneously and the content actually differs, one of the files will be renamed to
<filename>.sync-conflict-<date>-<time>-<modifiedBy>.<ext>. The file with the older modification time will be marked as the conflicting file and thus be renamed. If the modification times are equal, the file originating from the device which has the larger value of the first 63 bits for his device ID will be marked as the conflicting file. If the conflict is between a modification and a deletion of the file, the modified file always wins and is resurrected without renaming on the device where it was deleted.Beware that the
<filename>.sync-conflict-<date>-<time>-<modifiedBy>.<ext>files are treated as normal files after they are created, so they are propagated between devices. We do this because the conflict is detected and resolved on one device, creating thesync-conflictfile, but it’s just as much of a conflict everywhere else and we don’t know which of the conflicting files is the “best” from the user point of view.
Dropbox recently rewrote its sync engine and improved resolution of conflicts, discussed in their blog post. A Dropbox employee commented in 2017 that their client handles “hundreds of special cases”.
I have a lot of questions about how Syncthing’s sync works. What happens when directory trees are rearranged in conflicting ways? What about file and directory renames, symlinks, hardlinks, reflinks, filesystems that support different sets of features, unicode, case sensitivity, bind mounts, divergent metadata?
Maybe if I thought about it long enough I’d see that the FAQ answer resolves all of these questions, but I can’t yet reason about what will happen. In general, how can I predict what will happen to my data under a certain set of changes? Is there an overarching theory-of-syncthing sync that will reveal all this? Where is the relevant code handling these cases?
