subricky
(Ricky)
1
Dec 16 13:19:26 rbp-xfr1 syncthing[258601]: [SATWG] INFO: http://192.168.0.11:48135/rootDesc.xml - malformed InternetGatewayDevice description: no WANDevices specified.
Dec 16 13:19:26 rbp-xfr1 syncthing[258601]: [SATWG] INFO: UPnP parse: [http://192.168.0.11:48135/rootDesc.xml] Malformed device description: no compatible service descriptions found.
Is this something I can fix or is this something I should ignore?
bt90
(Bt90)
2
Does your router allow opening ports via UPnP?
subricky
(Ricky)
3
no. using opnsense firewall and we don’t allow unpnp. Eventually we will move the device to a DMZ where we can open a port.
I found this on disabling unpnp. I assume since we allow relaying there shouldn’t be a problem.
bt90
(Bt90)
4
The logoutput boils down to “upnp didn’t work” so that’s expected.
