I was looking at this issue: https://github.com/syncthing/syncthing-android/issues/57 but the outcome is not clear to me. I was looking at the Android GUI and at least could not figure out how to add a DNS address for a device.
I expect you can enter it in the same way and place as you would enter an IP address
Where it says dynamic I think, but I’m not an Android user. Entering something like tcp://foo.example.com should work if that is like the non-Android Syncthing.
Thanks! I will give that a shot.
And sort of as a follow-up question: if I want to expose a running Syncthing to the internet. How do I secure it?
