Correct configuration Domain, DynDNS or static IP addresses
Hello,
I use syncthing-fork on my Android Device and for a long time, battery consuming is very high. So I read some helpfull tips like this and this.
I use a Fritzbox with myfritz Service and connect this like DynDNS with my Domain. Now I have set in the App following settings and connection works. But I found not more Information, is the configuration realy correct.
Do I have to consider or change anything else?
I would be very grateful for an answer!
Sorry, but I am not sure whar the relation between the connection type and battery life is.
I guess if the connection works, then thats all that matters. I suspect in certain networks it might stop working, but then again, you are moving away from the safe working defaults, so presumably you know what you are doing and for what reason.
@AudriusButkevicius thanks for answer.
I don’t know but maybe it’s worth a try.
I guess if the …
I use Syncthing on some Devices about 5+ years and test something, but I am not sure about some things.
@Catfriend1 thanks also for answer. I have a Oneplus 6 with the official lastest Rom (10.3.5) without root. The battery drain started, I think 3-5 build before and interesting: when i install the app fresh and sync my folders the first day it works normaly. 5 minute synchronization is unfortunately no solution. I synchronize a Keepass database and this database changes very often
EDIT: Now looking a little bit closer at your screenshots. Do you have VPN on most of the time?
No, it’s not a VPN, just the app Blokada.
