Connection Problems
Trying to sync from a Windows PC to a Ubuntu PC.
It all worked OK but seems to have got stuck near the end of the first sync. All I see from the Windows PC is the Status (Web GUI) of the Ubuntu PC goes from connected to:
Address dynamic
kcp://[IPADDRESS]:22020
<small>deprecated protocol (17:48:38)
</small> tcp://[IPADDRESS]:22000
<small>No connection could be made because the target machine actively refused it. (15:49:05)
</small> tcp://[IPADDRESS]:7497
</small> kcp://192.168.1.213:22020
</small> tcp://192.168.1.213:22000
kcp://[fe80::c18d:106b:f0ec:daa2%25WiFi]:22020
<small>deprecated protocol (20:04:44)
</small> tcp://[fe80::c18d:106b:f0ec:daa2%25WiFi]:22000
On the Ubuntu PC the WebGUI either refuses to load (no page found) or a short connection followed by a message popping up with “Connection Error”
I’ve tried resetting the Database on the Ubuntu which seemed OK for a minute or so then went back to the same problem.
Just saw this in SysLog on Ubuntu machine:
Aug  7 18:07:47 ubuntu-laptop systemd[1860]: Started Syncthing - Open Source Continuous File Synchronization.
Aug  7 18:07:47 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: syncthing v0.14.43-ds1 "Dysprosium Dragonfly" (go1.9.3 linux-amd64) debian@debian 2018-02-06 04:01:09 UTC [noupgrade]
Aug  7 18:07:47 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: My ID: XXXXXXXXX
Aug  7 18:07:48 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Single thread SHA256 performance is 212 MB/s using minio/sha256-simd (129 MB/s using crypto/sha256).
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Hashing performance with weak hash is 182.65 MB/s
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Hashing performance without weak hash is 208.22 MB/s
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Weak hash enabled, as it has an acceptable performance impact.
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Starting deadlock detector with 20m0s timeout
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Ready to synchronize "Default Folder" (default) (readwrite)
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Ready to synchronize "Sync" (1zb0g-rl95q) (readwrite)
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Send rate is unlimited, receive rate is unlimited
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Rate limits do not apply to LAN connections
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Using discovery server https://discovery-v4-2.syncthing.net/v2/?id=XXXXXXXXXX
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Using discovery server https://discovery-v4-3.syncthing.net/v2/?id=XXXXXXXXXX
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Using discovery server https://discovery-v4-4.syncthing.net/v2/?id=XXXXXXXXXX
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Using discovery server https://discovery-v6-2.syncthing.net/v2/?id=XXXXXXXXXX
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Using discovery server https://discovery-v6-3.syncthing.net/v2/?id=XXXXXXXXXX
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Using discovery server https://discovery-v6-4.syncthing.net/v2/?id=XXXXXXXXXX
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: TCP listener ([::]:22000) starting
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: KCP listener ([::]:22020) starting
Aug  7 18:07:49 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
Aug  7 18:07:49 ubuntu-laptop systemd-resolved[685]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Aug  7 18:07:49 ubuntu-laptop systemd-resolved[685]: message repeated 9 times: [ Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.]
Aug  7 18:07:50 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Completed initial scan of readwrite folder "Default Folder" (default)
Aug  7 18:07:50 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Completed initial scan of readwrite folder "Sync" (1zb0g-rl95q)
Aug  7 18:07:50 ubuntu-laptop systemd-resolved[685]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Aug  7 18:07:50 ubuntu-laptop systemd-resolved[685]: message repeated 3 times: [ Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.]
Aug  7 18:07:50 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: <nil> for quic://31.124.170.25:22000: unknown address scheme "quic"
Aug  7 18:07:50 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Device XXXXXXXX is "Linux Laptop" at [dynamic]
Aug  7 18:07:50 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Device XXXXXXXX is "Windows Laptop" at [dynamic]
Aug  7 18:07:50 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: GUI and API listening on 127.0.0.1:8384
Aug  7 18:07:50 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Access the GUI via the following URL: http://127.0.0.1:8384/
Aug  7 18:07:50 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Established secure connection to XXXXXXXXXX at 192.168.1.213:53612-31.124.170.25:42432 (tcp-client) (TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305)
Aug  7 18:07:50 ubuntu-laptop syncthing[28883]: [JTUC2] INFO: Device XXXXXXXXX client is "syncthing v1.7.1" named "LAPTOP-DEPP2D1R"
Aug  7 18:07:52 ubuntu-laptop syncthing[28883]: panic: runtime error: slice bounds out of range
Aug  7 18:07:52 ubuntu-laptop systemd[1860]: syncthing.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Aug  7 18:07:52 ubuntu-laptop systemd[1860]: syncthing.service: Failed with result 'exit-code'.
Aug  7 18:07:52 ubuntu-laptop systemd[1860]: syncthing.service: Service hold-off time over, scheduling restart.
Aug  7 18:07:52 ubuntu-laptop systemd[1860]: syncthing.service: Scheduled restart job, restart counter is at 14126.
Any thoughts
If you can’t access the UI, it’s probably not running hence it does not connect.
Judging by the logs you are running incredibly old versions of syncthing that are no longer supported, so I suggest you upgrade first.
Your Ubuntu machine runs a very old version of syncthing which will always crash when syncing any larger file (this probably due to your Ubuntu repository not offering anything newer). The Windows PC is up to date. Syncthing’s own apt repository (apt.syncthing.net) has the latest versions for Debian/Ubuntu machines.
Thanks very much, assumed Ubuntu repository was up to date! Should be removed from there if it’s not up to date. It’s all working fine now, thanks again.
The official Ubuntu (or Debian) repositories contain software packed by the Ubuntu (Debian) maintainers and the syncthing team has no control over what software they package or which versions they distribute.
This is just the way how (official) debian-style repositories work. They tend to package one version at time x, then go use that version for a bunch of years and only update when the user upgrades to a newer distro version. This is fine for software where development is slow, but it’s not really suited for the fast development of syncthing.
OK, a lesson for me. Thanks again for your help.
