Hi all, new to syncthing so please bear with me. Have tried to find the solution through the forum like restarting syncthing but still cant get it to work.
So I have syncthing (v. 1.7.0) installed on:
openmediavault 5 through docker;
my android phone; and
my windows 10 laptop.
I have all of the connections setup between the above 3 devices. All showing as connected.
From openmediavault drive to my phone created a shared folder but it says syncing 0% and there files not syncing are listed in the out of sync items.
Yes its version 1.7.0 everywhere. Tried pausing/unpausing folders.
On my phone, it shows under Devices - OMV “Up to Date”. Under Folders, nothing - do I also need to add the folder from OMV here as well or is that automatic once it links?
I managed to get it to work - It seems you have to add the folder twice. Once on the server side and then again on the other side (in the app) and then it began syncing. I thought it would just automatically link it once the devices are connected.
But thanks for pointing me in the right direction. I spent weeks trying to get resilio to work and gave up. Yet in 3 hours since I started syncthing - it all works.
Just a another related question on the app, is it possible to add a password or is that only on the webUI?
Password to access the app like there is to access the webUI.
May have spoken too soon, the sync folder between my openmediavault and phone got up to 69% and now has stopped for over an hour. Tried restarting all devices, pause/unpausing but still not moving from 69%.
Not sure how to post the logs/screenshot from the phone side?
I also see a lot of ‘addresses’ in the logs - i presume there is nothing private in those logs when posting on the web?
