Android and Debian
Hello, I am running Syncthing v1.0.0-ds1, Linux (64 bit) on a Debian machine using the default repositories. Upon upgrading my Android phone to 1.17, the two would no longer connect to each other. When I downgraded the Android device back to 1.16, everything worked fine. Please let me know if you need log files or something. Thanks for your time.
You need to upgrade the v1.0.0 instance: apt.syncthing.net
See e.g.
Thanks! Will do.
