Advice on using syncing with 3 computers
Ola!
I would like to ask for some advice on properly syncing 3 computers,
The 3 computers:
  1. Home PC (A)
  2. Work PC (B)
  3. NAS (C)
I’ve bought a used synology nas (C) for the purpose of syncing files remotely.
I was able to accomplish this using Dropbox style sync in which I sync files from the NAS (C) which acts like a Dropbox Server for Home PC (A) and Work PC (B)
There is no link between (A) and (B)
(B) ↔ (C) ↔ (A)
Is this the syncthing way?
Or Should I create a link between (A) and (B)?
I’m a bit hesistant to link the (A) and (B) because I have bad internet connection here. There would be times I have no internet connection and so cannot remotely sync, I need to bring the Work PC at home to sync with the NAS. My concern is that if connect the 3 computer, and I was not able to sync with the NAS fully and the Work pc sync with the Home PC then there would be problems.
I’ve read some thread regarding this, but I just want to be sure.:smiley:
TIA!
As long as they’re connected to each other somehow (i.e., b-c-a) things will work. It’s not necessary to also connect b to a unless you want data to flow directly between those devices.
Thank you calmh! I will stick with my current setup for now. :blush:
I use this kind of setup for my personal needs regularly.
