After restoring my Syncthing setup from a backup on a fresh Android—without copying over the actual synced folders—Syncthing removed all files from my laptop. Fortunately I had versioning turned on for all folders, so nothing was lost. After some searching I found two ways to easily restore versions for thousands of files:
- With a tool for Windows built by julien.robin28, see Code share : Syncthing-Restore for .stversions folder
- With a shell script that strips the timestamp from version filenames, see Restore original name versioned files with linux command
I’ve worked out yet another way, through the web interface:
Click on the folder you’d like to restore versions for.
Click “Versions”.
Run this jQuery in your developer console to select the second option of every dropdown in this modal—which happens to be latest version:
$(’#restoreVersions ul.dropdown-menu li:nth-child(2) a’).click()
Go grab a cup of coffee, this might take a while, depending on how long the list is.
Click “Restore” at the bottom of the list.
I can’t guarantee that this selector will always work, but it did today and for me.
Good luck.
