Let me first explain the 2 requests im asking for. and then i will give a usecase.
1. Wildcard #include
In current implementation, you can use #include
on your .stignore
file to attach additional ignore rulesets. However, it seems like each line of #include
can only include 1 file. instead (or in addition?), i suggest allowing for wildcard #include
's, which means that you can targate multiple rulesets from a single line. for example: #include **/.project-stignore
would targate any files named .project-stignore
in ever folder apply those rules.
2. Relative #include
As we all know, the files attached using #include
, the rules of those files are applied as if the file was in the root of the share folder. for example, if i had #include /project1/.project-ignore
and this file contains a rule /myfile.txt
, then that will exclude a myfile.txt
from the root of the share folder. if the rule was myfile.txt
instead, then this would ignore any file in any folder named myfile.txt
. But if i wanted to targate /project1/myfile.txt
, i literally have to spell out exactly that path.
But instead, if the included ruleset could retain context of the folder it was in (you can simply append the folder path dynamically to every rule/pattern within the file, or have a character that you could add to the rules to inject the folder in which the rules were fetched) that would help a lot of people using this for development projects.
Here are 2 methods i suggest:
A: in addition to #include
, you can have #includeRelative
or something similar. This would work the same as #include
does, but instead, every line on the ruleset attached using #includeRelative
would get the directory appended to the start. ie. #includeRelative /project1/.project-ignore
on the .stignore
, and the .project-ignore
states /myfile.txt
, then the rules would see /project1/myfile.txt
thus the only file that would be ignored would be just that.
B: introduce a new character to the ignore rules files (similar to *
etc) where the character would be replaced by the folder in which the rules file exist. Lets say the character is @
. This means: #include /project1/.project-ignore
on the .stignore
states @/myfile.txt
Use case (for both requests)
Im a developer. I work on lot of web and mobile development projects. Projects get added, removed, renamed reasonably often. I have multiple computers that i do development on, which i would like to have my project folders synced in. my projects are stored in the following way (fail directory tree to text attempt):
/MyProjects
-/CoolProject
-/NotSoCoolProject
---/ActualDevFiles
-/CatPics
I would like to “share” my MyProjects
folder (which is the root of all the projects). Most of the projects have build scripts and such, which creates build
, bin
, dist
folders on the fly, which would be horrible for syncthing (because constant syncing while im developing would be too much). Obviously, i cannot add these folders as wildcards since the project might have dependencies (like node_modules
which might also have bin/build/dist folders). So them my ignore rules are going to look like this:
/CoolProject/bin
/CoolProject/build
/CoolProject/dist
/NotSoCoolProject/ActualDevFiles/bin
/NotSoCoolProject/ActualDevFiles/build
/NotSoCoolProject/ActualDevFiles/dist
…you see where this is going right?
There are lot of other use cases too. Specially if you can do wildcard #include
, then adding a new project means you simply copy a rule file from a similar project into your projects main folder (thats all, see how simple it is?), and renaming a project folder (assuming you already have the rules file in there) means you dont have to do anything at all.
In the above example i only showed a ignore ruleset of 3 items, but in reality a project has a huge amount of files that should be ignored from syncing, being developers you guys should be more than familar. Here is an example of a Seed Project ignore file im dealing with: https://github.com/NathanWalker/angular2-seed-advanced/blob/master/.gitignore
. Imagine if it was the Syncthing Project: https://github.com/syncthing/syncthing/blob/master/.gitignore
Keep in mind, what im asking for should not affect any existing users, its simply extended functionality for advanced users.
If you guys think the feature request is legit, but dont have the ability to do it, but would allow a random developer (me) to try it, i might even be able to take a crack at it. If someone could give me some rundown on how i would run/test/debug and give me a quick overview, i would be happy to take a crack at it at somepoint
Cheers
