Hello.
After the last (2 if I recall correctly) updates , synching runs in the background no matter what. WiFi on/off ,4G, and even with no connection at all .
Any help would be much appreciated, thanks!
Hello.
Tested on 2 devices running android M & android N and i get the same result. Wifi only doesn’t seem to work.
You’ll have to report this to the developer of the mobile app directly (through the Play Store). The Android app is a wrapper to Syncthing and is not developed by the team here.
I think the issue is known. If you check syncthing-android github repo you should see open issues.
