Hi, I’m having an issue with a Realme 14 Pro running Realme UI v16.0.5 and a Redmi Note 14 Pro on Android 16. For the option ‘Start on selected Wi-Fi networks’, when I try to select a network, it says that Wi-Fi needs to be enabled first—even though Wi-Fi is already turned on. All permissions, including location services, have already been granted. Is there a solution for this? Thanks a lot for the help!
Can you confirm that the app is allowed to access location “all the time” (see the screenshot below)?
Hy. Yess, this is turned on Allow all the Time. On the Realme it solved the Problem, but on the Redmi its still the same Problem
