Hi
I installed .9 and I see multiple ports going on in the settings. Which port I am forwarding on my router so clients can see eachother and transfer files?
thanks
Hi
thanks
Solved my issue. I had to reinstall all clients and created all the settings from scratch for the new .9x series.
It feels much better than .8 both on linux and on Android.
Glad it’s solved, but that shouldn’t have been necessary. Does https://forum.syncthing.net/t/firewalls-and-port-forwards/166 clarify the port forward situation?
