Where exactly is this setting located ?
Help a new user out, where is 2.6.2. “Send Only Folder” option located in the GUI? Step by step instructions please I have clicked on everything I can find so many times I am confused.
As seen here
https://docs.syncthing.net/users/foldertypes.html#send-only-folder
Only if that screen capture was a little higher might be able to locate in the GUI… No hints given that I can see I bet a season user knows?
Thanks
The GUI has seen some redesigns over time, documentation may not be 100% up to date.
In a modern version you can find this setting under Add Folder -> Advanced -> Folder Type.
If the folder already exists, click on the folder name & chose Edit / Advanced / Folder Type.
