I want to edit the actual xml files because ST Android is throwing chmod errors every second, no good for me. The Gui does not show the repo but the web gui does. However the web gui does not let me save the changes therefor I need to figure out where the actual settings are residing.
The repo shows to ignore permissions but the logs do not seem that way. I have millions of these
I just want to force it to rescan and recreate its sync status (properly). It keeps recreating the deleted folder with dot versions of the files in it even after I removed them from the other node as well.
I looked into .config/syncthing but that does not have the repo I have not sure if that is from some older versions.
I am on a rooted system using ST And Arm7 0.5 beta
What is interesting is that when I run ST binary as root it creates the config files under /storage/emulated/0/.config which is weird because this is where normally it should have created in the first place. When I run the app as a noirmal user all the data is created under /data/data/com.nutomic which can only be accessed by root.
