This is the original PR that introduced Staggered File Versioning:
https://github.com/syncthing/syncthing/pull/541.
The config.xml
syntax back then looked as follows.
<versioning type="staggered">
<param key="versionsPath" val="xxx"></param>
<param key="cleanInterval" val="3600"></param>
<param key="maxAge" val="31104000"></param>
</versioning>
Nowadays, the syntax has changed into this.
<cleanupIntervalS>3600</cleanupIntervalS>
<fsPath></fsPath>
<fsType>basic</fsType>
</versioning>
My question is essentially about the two values listed in cleanInterval
and cleanupIntervalS
. The latter is the normal cleanup interval that we can also set using the GUI. The former though isn’t presented in the GUI anywhere, and its value is always set to 3600
The original explanation of cleanInterval
was “cleanInterval is the interval between scanning all versions and deleting ones that are too old or when too many are in a interval (default 3600 s = 1 hour)”. Frankly speaking, I can’t grasp the difference between this and the normal cleanupIntervalS
In other words, are the two actually different and is cleanInterval
actually used in the current code?
