Web interface login (credentials)
Hi! I just started using syncthing for a few week and all of a sudden, I’m asked for credentials when I try to open the web interface on my Mac (M1, Brave Browser). I tried syncthing / [API Key] as I read somewhere, but this does not work.
So:
  • What are the default credentials?
  • If I had set them and don’t remember, how can I reset them?
Thank you very much for your help!
-Patrick-
The default is no credentials. See this FAQ for how to reset them: https://docs.syncthing.net/users/faq.html#how-do-i-reset-the-gui-password
Thank you very much for your answer André! =) So how did I log in to the web interface without credentials before?
But more important, the FAQ says:
syncthing generate --gui-password=myNewPassword --gui-user=newUserName
But where do I enter that? If I put it in the terminal, it only says “zsh: command not found: syncthing”
What am I doing wrong here?
I suppose that depends a little on how you installed Syncthing. If you used the Application Bundle for MacOS then you first have to dive into the Application Bundle;
cd /Applications/Syncthing.app/Contents/Resources/syncthing
There you can run
./syncthing generate --gui-password=… --gui-user=…
(obv the above two steps can be combined)
Or if you rather just modify config.xml yourself using some text editor, this should be - per default - available as;
~/Library/Application\ Support/Syncthing/config.xml
There you can just remove the user and password tags within the gui part.
Thank you very much! With viewing the config file, I remembered the login I gave it initially.
Thanks for the help - solved my problem! =)
