Yes and No. This depends on the type of the service (e.g user vs system service) and if the service is enabled or not.
Your configuration shows Loaded: loaded (/lib/systemd/system/syncthing@.service; enabled; vendor preset: enabled), which means that the service is enabled and auto-starting at system boot.
Systemd usually auto-restarts services when they crash. When you first executed the command, the service had just crashed and was in the process of restarting automatically, see your inital output:
Active: activating (auto-restart) (Result: exit-code) since Wed 2021-05-26 15:02:48 AKDT; 827ms ago
Naturally, a few seconds after the auto-restart everything is up and running again. As to why it crashed in the first place - no idea, probably need to look at more detailed logs.
It seems I’m caught in a loop, with the service constantly restarting and then crashing:
May 27 12:17:47 BACKUP1 systemd[1]: Started Syncthing - Open Source Continuous File Synchronization for admin.
May 27 12:17:47 BACKUP1 syncthing[25918]: [start] INFO: syncthing v1.15.1 "Fermium Flea" (go1.16.3 linux-amd64) deb@build.syncthing.net 2021-04-06 08:42:29 UTC [noupgrade]
May 27 12:17:47 BACKUP1 syncthing[25918]: [start] INFO: Using large-database tuning
May 27 12:17:47 BACKUP1 syncthing[25918]: [V4C2B] INFO: My ID: [REDACTED]
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Single thread SHA256 performance is 252 MB/s using minio/sha256-simd (233 MB/s using crypto/sha256).
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Hashing performance is 214.79 MB/s
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Overall send rate is unlimited, receive rate is unlimited
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Listen (BEP/quic): listen udp 0.0.0.0:22000: bind: address already in use
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Using discovery mechanism: global discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Using discovery mechanism: global discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Using discovery mechanism: global discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: c.S.listenerSupervisor: Failed service 'quic://0.0.0.0:22000' (1.000000 failures of 2.000000), restarting: true, error: listen udp 0.0.0.0:22000: bind: address already in use
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Using discovery mechanism: IPv4 local broadcast discovery on port 21027
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Using discovery mechanism: IPv6 local multicast discovery on address [ff12::8384]:21027
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Listen (BEP/tcp): listen tcp 0.0.0.0:22000: listen: address already in use
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: c.S.listenerSupervisor: Failed service 'quic://0.0.0.0:22000' (1.999998 failures of 2.000000), restarting: true, error: listen udp 0.0.0.0:22000: bind: address already in use
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: c.S.listenerSupervisor: Entering the backoff state.
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: c.S.listenerSupervisor: Failed service 'tcp://0.0.0.0:22000' (2.999997 failures of 2.000000), restarting: false, error: listen tcp 0.0.0.0:22000: listen: address already in use
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: c.S.listenerSupervisor: Failed service 'quic://0.0.0.0:22000' (3.999984 failures of 2.000000), restarting: false, error: listen udp 0.0.0.0:22000: bind: address already in use
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Ready to synchronize "Files" [REDACTED] (sendreceive)
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] WARNING: Failed starting API: listen tcp 0.0.0.0:8384: bind: address already in use
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Failed initial scan of sendreceive folder "Files" [REDACTED]
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] WARNING: Starting API/GUI: listen tcp 0.0.0.0:8384: bind: address already in use
May 27 12:17:48 BACKUP1 syncthing[25918]: [V4C2B] INFO: Exiting
May 27 12:17:48 BACKUP1 systemd[1]: syncthing@admin.service: Main process exited, code=exited, status=1/FAILURE
May 27 12:17:48 BACKUP1 systemd[1]: syncthing@admin.service: Unit entered failed state.
May 27 12:17:48 BACKUP1 systemd[1]: syncthing@admin.service: Failed with result 'exit-code'.
May 27 12:17:49 BACKUP1 systemd[1]: syncthing@admin.service: Service hold-off time over, scheduling restart.
May 27 12:17:49 BACKUP1 systemd[1]: Stopped Syncthing - Open Source Continuous File Synchronization for admin.
Apparently there’s some sort of ‘shadow process’ already using these ports.
I’m completely lost on how to troubleshoot this (let alone fix it).
root@BACKUP1:~# systemctl status syncthing@root.service
…revealed that it was truly dead, so I tried browsing to the GUI. Success.
Everything fell into place on its own with the peer, and 3GB of new/updated files synced without me having to do anything more.
Just to be safe, I rebooted the device and ran another ps auxwwf | grep syncthing. Problem solved. (Although I would someday like to learn how to fully clean out those files/settings from when I was incorrectly running the service under root.)
