I think I must be overlooking something simple… Maybe an android setting or permission I need to toggle(?) I’ve been using Syncthing-Fork on my android phone and LOVE it for my home server running windows 10 <> phone. I use Broadcast Intents via Macrodroid to sync it based on my liking.
But with server <> ChromeOS utilizing the same setup (using the same mobile Android apps, NOT Linux), I get a warning in the Web GUI on the chromebook, “Filesystem Watcher Errors” “For the following folders an error occurred while starting to watch for changes. It will be retried every minute, so the errors might go away soon. If they persist, try to fix the underlying issue and ask for help if you can’t.”
I’ve powerwashed the chromebook and tried a couple different syncthing folder locations. “Internal Storage\SyncthingShare” (same as my mobile) and “Downloads\SyncthingShare” (since sometimes ChromeOS seems finicky about letting me see root folder from various apps while “downloads” seems to always be visible.
Any suggestions?
