I’m leaning towards a bug on this…
I have tried different ways to get the versions folder to move to another location, but nothing works. So far I have…
set the config.xml to point to h:\
set the gui (edit / file versions) to point to h:\
made a directory on h:\older
made a directory called h:\.stversions
made a subdirectory called .stversions within the test 'older’directory
tried all of the above with H rather than lowercase h in case there was case sensitivity issues
delete the original .stversions folder, but it gets recreated
tried all of the above on all the other versioning options and restart St on each change
it seems the only versioning that works is simple and using the default location
I have seen this has been recently added…
So I wonder if somehow the versioning has been broken with this being introduced?
windows 1.14 rc2
