I’m using Staggered File Versioning between 2 PC’s with great success - it’s saved me a couple of times from deleted, corrupt files.
The versioning files are stored in a separate folder (C:\Sync-Deleted)
Now I’m going to backup all my actual data and would like to clear-out/Reset the versioning files.
What’s the best/clean way to do this ? 1). Just delete all the files/folders under the C:\Sync-Deleted 2). Turn off Versioning and then delete 3). Some other way ??
What ever way I don’t want to corrupt any databases that syncthing is/maybe using.
Many thanks for some great software
Leigh
