I have a handful of notices in GUI telling me files in the .stversions folder are ‘no such file or directory’ How should I interpret this?
Dunno. What does it say, exactly?
2017-09-29 14:36:34: versioner: lstat /Volumes/xxxxxxxxxx. PDF~20170923-160423.pdf: no such file or directory
Do you really have a volume called xxxxxxxxxx. PDF~20170923-160423.pdf that it is somehow complaining of? That seems unlikely.
(Yes, I said “exactly” for a reason.)
(no its a redaction) So I just sort of put together that lstat is a command and the no such file or directory is result of the operation. I can probably figure the rest out. Thanks.
