Vellum - warm light & dark themes for the web GUI
Made these for myself a while back and figured I’d share them in case the look is anyone’s taste.
Both are just a single CSS file and a small logo, so install is the standard route — drop the folder into your config’s gui/ directory, then pick it under Actions → Settings → GUI → Theme.
Tested on macOS with the current Syncthing release. If something looks off in your version, drop an issue on the repo.
