If you use WSL then you might wonder how to use syncthing. It’s easy! I would recommend installing syncthing directly within the WSL container that you often use. After that just create a new shortcut within your Startup folder in the start menu:
%APPDATA%\Microsoft\Windows\Start Menu\Programs\Startup
wsl.exe --exec syncthing
wsl.exe Options:
--distribution, -d <Distro>
Run the specified distribution.
--user, -u <UserName>
Run as the specified user.
That’s it !
