Using AI tools to fix bugs
I once again ran over a problem with strelaysrv and ip aliases and connecting to the pool servers.
Since our setup is quite rare and trying to explain the issue needs a deep insight in our system/network setup I just gave some clanker a job and tried to see if it would fix the bug.
Well, it did. It found 3 ‘bugs’ and a race condition which results in our strelaysrv not getting registered at https://relays.syncthing.net/endpoint.
Without going into detail now, I would like to know how to proceed. I can tell it to write a forum-post, a github issue or even create a pull request. I don’t want to put slop here, and I also don’t want to pose as the supa-dupa-bug-hunter, since all I did was kicking the clanker until the bug was fixed.
any thoughts ?
Peter
Report the problem you experienced, as an issue, described by you as a human.
And thank you for asking :heart:
