I have 2 computers on the same network; and would like to be syncing them over LAN. However, syncthing seems to be using the internet rather than LAN, and i can’t figure out why.
Do you only want to sync in LAN?
Then you can simply enter local IPs or hosts as address (see docs) instead of “dynamic” and disable NAT, local discovery, relaying and global discovery.
Awesome; that worked perfectly. Thanks!
