I searched FAQ’s butdid not see an answer
I have 3 systems syncing 45GB (two windows 8 and a wdmycloud)
They are currently on v0.12.14 and all in sync and have been since installation my questions are:-
- can I upgrade from v0.12.14 to v0.14.9 in one step or do I have to go through V0.13.?
- when I upgrade do I disconect them and upgrade one at a time then reconnect them? is there a reccomended proceedure?
Regards
Paul
It’s probably easier to get them fully in sync, and just rebuild from scratch, with new IDs, etc, etc.
calmh
(Jakob Borg)
3
Hm? It should upgrade just fine, but being in sync when doing it is preferable as it will do a full rescan.
Thank you for the responses, I decided to go for an upgrade and took the following
steps.
- Ensured all systems in sync with each other
- Isolated all three systems
- Upgraded each system and allowed the scan to complete
- Connected two systems and allowed to report fully synced and then connected the final system.
I did get a couple of conflicting files but these were easily resolved.
system
(system)
Closed
5
