Yesterday I upgraded to v1.20.3 with “docker-compose pull” and “docker-compose up -d” commands. The problem is that after this I lost my configuration. This happens bacause composer recreated /config folder?
I guess that depends on your compose file. You should use a volume for the config and database, which would persist it accross container recreates.
This is my yaml:
version: "3.9"
services:
syncthing:
image: syncthing/syncthing:latest
container_name: syncthing
hostname: syncthing
environment:
- PUID=33
- PGID=33
- TZ=Europe/Rome
volumes:
- /var/lib/docker/volumes/syncthing/config:/config
- /srv/dev-disk-by-uuid-83ecb729-27d8-492f-9a9e-94832266f12a/Nas:/nas
ports:
- 8384:8384
- 22000:22000/tcp
- 21027:21027/udp
restart: always
The strange thing is that /var/lib/docker/volumes/syncthing/config is empty.
Our container image doesn’t use /config where you’ve mapped the volume, it uses /var/syncthing. We apparently even have a compose example nowadays.
That was the problem, thanks!
