Updating to latest release
I have an Asustor that is running on v12.22 with an Intel Atom processor.
Is the new v14.44 compatible with that? I don’t see a Linux-ATOM tar.gz
Thanks, Dave
Atom is a regular Intel processor. If you can, log in and run uname -m. If it says “x86_64”, use the “amd64” release, otherwise try the “386” variant.
Thats what I suspected, but since it was supposed to compete with ARM I didn’t want to install the wrong one manually.
Thank you Jakob.
Apparently, it requires APK. I guess Ill try to find the android version.
I doubt this will work and is probably over my pay grade.
