I installed v0.14.26, Mac OS X (64 bit) to work on a specific project. That project is now finished and I would like to remove Syncthing. What is the most straightforward means of doing that. I’m on OS X version 10.12.4.
Remove the binary or do the opposite of whatever you did to install it (i.e., if you installed by homebrew, uninstall by homebrew).
Remove ~/Library/Application Support/Syncthing
Live happily ever after.
