Uninitialized entry in Advanced Configuration/Default Folder/Devices
Syncthing 1.23.1, linux.
Right after vanilla startup there seems to be an uninitialized entry in “Actions” / “Advanced Configuration” / “Default Folder” / “Devices”
I would object to ‘[object Object]’ being an initialized entry. :sunglasses:
File an issue ?
Cheers, Peter
Good old object Object… Advanced config doesn't handle arrays of objects · Issue #4569 · syncthing/syncthing · GitHub
