Hi there
I’ve several folders syncing between 4 PCs all over town … works really, well thanks.
I started a new folder to sync and specified it was to share to 3 of the PCs.
Then I went to each PC to click OK/ Accept and tell it which local folder to use.
One on of the PCs I stupidly clicked “Ignore” (I got distracted) and now I can’t get that folder Accept dialogue popup to appear again.
How do I reset the “Ignore” setting when accepting a folder sync for the first time?
